Results 1 to 15 of 20
Thread: SN26P PCI-E card
    Enthusiast
    53
    Default SN26P PCI-E card
    Hey people. need some help, to long to post on here, would someone mind adding me to msn uperkurk@gmail.com
    Thanks in advance
    P.S someone that knows alot about shuttle systems.
    Enthusiast
    53
    Sorry for double post, will a Inno3D Geforce 6800GS 256MB DDR3 PCI-E card be able to play bf2, requirements say i need a certain chipset.
    the chipset for the SN26P shuttle is NVIDIA nForce4 SLI, dunno if that is good enough. is my chipset the same as below?
    Video card must have 128 MB or more memory and one of the following chipsets:
    NVIDIA GeForce FX 5700 or greater
    ATI Radeon 8500 or greater
    you should be fine with that card
    Inno3d 7300gt ddr3 would be better and costs around £60ish (for the 256mb version) if you shop around, wish Aria would stock them as o recommend them quite a bit to people looking for a reasonable yet cheapish card for gaming.
    AHA see Aria now have a 7300gt ddr3 in their stocklist 8) , though they are currently out of stock
    http://www.aria.co.uk/ProductInfoComm.asp?ID=25130
    oh, i thought you meant that the 6800 was the card you already had...! yeah, the 7300 would be good too
    Enthusiast
    53
    Is the 7300 compatible with the SN26P shuttle tho?
    If your shuttle has a pcie graphics slot then yes its compatible as is any other pcie graphics card.
    You can put ANY single pcie graphics card into ANY motherboard that has a matching pcie graphics card slot. Just because your motherboard has an nvidia or ati chipset doesn't limit you to an nvidia or ati graphics card respectively. I have an ati graphics card running perfectly happily in my nvidia chipset motherboard i would only need to run nvidia graphics cards if i wanted to run dual graphics cards as it is an sli motherboard, which is the nvidia dual graphics card setup. Likewise i could use a nvidia graphics card on a motherboard with an ati chipset but if i wanted to use dual graphics cards in a crossfire setup, ati's equivalent of sli, then they would have to be ati cards.
    Sorry if this is a tad confusing but you aren't the first inexperienced pc user, no offence intended, that has fallen for this misconception.
    I still stand by my suggestion of the 7300gt ddr3 graphics card though. 8)
    Enthusiast
    53
    Confusing? thats the best help ive had, i mean, why couldnt all the other people tell me that.
    What 7300gt card, theres about 7 diffrent 7300gt cards on aria?
    Thanks alot m8, one thing tho, why does the SN26P shuttle site have only a few compatible gfx cards? have a look;
    http://eu.shuttle.com/en/DesktopDefa...33_read-11626/
    One more thing, when i bought the SN26P comp it came with a book about the bios settings, do i have to set all the bios settings myself or does it come pre configed.
    Enthusiast
    53
    Will the POV Nvidia 7900GS-256Mb PCI-E card work ?
    No idea why they only list a few gfx cards on the shuttle website though from the look of it it hasn't been updated in a while as some of those are pretty old cards.
    If you were going to go for a 7300gt from Aria then i would suggest you get the one i linked to in my other earlier post but heres the linky again :wink:
    If you need to look elsewhere for one because that one is out of stock make sure the one you get is DDR3 as they are far far better than the ddr2 version of the 7300gt.
    Again for the same reasons i gave before i see no reason why the 7900gs wouldn't work in a shuttle, i know someone who was running a 7800gtx in a shuttle so the 7900gs should work too
    Hazardous Biodoid's Avatar
    Salford + Popovka + Looking to move to Nazdedurnia
    2,427
    37
    try looking out for the Galaxy version of the 7300GT as that has ddr3 plus is factory overclocked and has been benched faster than a 7600GS :wink: plus it has a nice Zalman cooler on it
    Main PC: Q6600 / 8 gig DDR2 800 Patriot Dual Channel / Asus P5N-E SLI / EVGA 560Ti DS "Superclocked" / Intel X25-V 40gig / Asus Xonar D2 / Antec 900 Case / BenQ G2222HDL / G15 Keyboard v1 / Windows 7 Ultimate
    Desire Owners Club Owner # 13
    Enthusiast
    53
    Well, just found out that the POV Nvidia 7900GS-256Mb PCI-E wont work because its to wide and the 7300GT is rather cheep, cant be that good?
    Because i dont no much about computers i have to ask about everything ops:
    Can someone please answer this question for me plz
    For the money the 7300gt is a little belter, a mate of mine has an 850XT clocked to PE speeds and my 7300gt almost benchies as high as that, it does the Counterstrike Source video stress test with almost 90fps average @ 1280x1024 max details and 1 setting of AA and AF now for aprox £60 there aren't many other cards that can touch it. Granted next to a card costing 3x as much (7900gs etc) it will get stomped on in the performance stakes and no its not a hard core gamers card but it will play BF2 reasonably well if the rest of your setup is upto it, ie 2gb of memory is almost a must for BF2 and might improve things almost as much as a new gfx card.
    As for the bios settings nope you shouldn't need to touch them it should sort out itself.
    Enthusiast
    53
    Just been looking at the 7300gt DDR3 and i think 2 of them would work good but i dont no if my 350w psu can handle it and make full use of them? what your ideas guys.
    Does 2 cards mean 2x the performance?
    Your psu should be fine, for some strange reason shuttle psu's are grossly under rated 350watt doesn't mean alot in a shuttle for some unknown reason, know a guy who was running dual 7800gtx's in his ok so 2 7300gts should be fine.
    No 2x graphics cards doesn't generally give twice the performance, dunno why but it just doesn't it WILL give a big boost somewhere in the reagion of 50% to 60% if not more but no not double.
