I'm trying to check if a drive exists, if it does I need to remove it and rename as the old name sticks for some reason. This is what I have right now:
it changes the path but the old name stays for some reason - any ideas?Code:Set objFSO = CreateObject("Scripting.FileSystemObject")Set objNetwork = CreateObject("Wscript.Network") if objFSO.folderexists("O:") then objNetwork.RemoveNetworkDrive "O:", True, True objNetwork.MapNetworkDrive "O:", "\\srv-fs\shares" set renameShell = createObject("shell.application") mappedDrive = "O:\" renameShell.nameSpace(mappedDrive).self.name = "Shares (\\srv-fs-shares)" End If
