Results 1 to 11 of 11
Thread: vb script add, remove, rename network drive help
    Aria Resident cinek's Avatar
    Nov 2010
    3,376
    642
    Default vb script add, remove, rename network drive help
    I'm trying to check if a drive exists, if it does I need to remove it and rename as the old name sticks for some reason. This is what I have right now:
    Code:
    Set objFSO = CreateObject("Scripting.FileSystemObject")Set objNetwork = CreateObject("Wscript.Network")
    if objFSO.folderexists("O:") then
    	objNetwork.RemoveNetworkDrive "O:", True, True
    	objNetwork.MapNetworkDrive "O:", "\\srv-fs\shares"
    	set renameShell = createObject("shell.application")
    	mappedDrive = "O:\"
    	renameShell.nameSpace(mappedDrive).self.name = "Shares (\\srv-fs-shares)"
    End If
    it changes the path but the old name stays for some reason - any ideas?
    3770k | MSI Twin Frozr GTX570 | Mushkin Blackline 16GB | Noctua NH-D14 | Samsung 840 Pro 128GB | Crucial M4 128GB | Gigabyte P67A-UD4-B3 | SoundBlaster X-Fi Fatal1ty Pro | Corsair AX850 | Fractal Design R3
    345
    The name you are setting via your script would be stored in the registry. Ini files can also store drive labels, e.g.desktop.ini. Check these?
    Nov 2010
    3,376
    642
    Nope haven't checked those. But if the drive is removed why would the old entry still be present in the .ini file or the registry?
    /dev/null Plan9's Avatar
    Aug 2011
    /root/
    2,291
    315
    It's been a while since I've done this in VBS, but it sounds to me like a Windows bug. Restart explorer.exe to see if the name is persistent.
    Nov 2010
    3,376
    642
    nope, still the same
    345
    Quote Originally Posted by cinek View Post
    Windows remembers any drives that have been mapped or connected.
    The machine I am on right now is Vista so might be different for you, take a look at HKCU\Software\Microsoft\Windows\CurrentVersion\Exp lorer\MountPoints2
    Nov 2010
    3,376
    642
    the strange thing is, the drive dissapears after I restart my pc
    345
    As in the drive mapping is not a persistent mapping?
    Even if the drives is not shown as mapped, the registry holds information about it including drives such as USB memory sticks.
    Nov 2010
    3,376
    642
    Quote Originally Posted by Hax View Post
    yeah, when I map the drive by running the script manually, it doesn't stay map the next time I turn on the pc ;/
    345
    Then change this line to:
    objNetwork.MapNetworkDrive "O:", "\\srv-fs\shares", True
  11. The Following User Says Thank You to Hax For This Useful Post:
  12. #11
    Nov 2010
    3,376
    642
    thanks, I'll try that on Monday
